I put this in the wrong forum. Hope this is a better choice.
Some earlier designs have the knock sensors inside the engine, under the intake manifold. This is a great spot for listening to the knock of the heads, but bad for access.
I have seen some that are mounted outside, with a bolt thru the center. This allows for easier access for repairs.
I have heard they pick up different frequencies then the older type. This may have been needed in order to put them someplace else. They have 2 leads instead of one and ground.
Here is the question: Are the compatible? It seems it would be so much easier to simply get the external sensor, bolt it on, ground out one lead and tap the other into the wire harness.
You would have to take things into consideration, such as noise, heat and proximity to the head for optimal sensitivity. But this sounds like it should work.
