Stock Radio Volume on 2000 LE no workie - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2011, 03:49 PM   #1 (permalink)
Wizard Prang's Avatar
View Wizard Prang's Photo Gallery
4th Generation Stock Radio Volume on 2000 LE no workie
The Car: Gen4 (2000) Camry LE w/ stock radio
The Problem: The volume of the stereo does not work; turning the volume knob has no effect. All other buttons seem to work fine, but I am getting no sound at all out of it.
Is there a fuse or a relay I need to inspect, or does the stereo need replacing?
Who is General Failure and why is he reading my Disk?
Wizard Prang is offline   Reply With Quote
Old 10-06-2011, 06:41 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
likely the head unit went bad. I had similar trouble with the Tune in knob on factory stereo unit in my car. behind the knobs are variable resistors usually, that's what goes bad with age on those units. not to mention frequently non-working CD players in old Toyota head units.
Instead of fixing or replacing with same old stuff from junk yard, I'd rather consider getting a modern stereo head unit from best buy or crutchfield's. well worth it.
Tags
radio volume sound stereo
