I need Help. Hit Roadblock! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2011, 07:46 AM   #1 (permalink)
Bdub215's Avatar
Gameroom cash: $316065
View Bdub215's Photo Gallery
My speedo hasnt been working since i put my new transmission back in my car. I replaced the VSS with a known good unit and i just did the wheel speed sensors (ABS light) yesterday but its Still not working. my Tach and fuel gauge still work. I'm thinking its a minor detail that i'm overlooking. Any suggestions?
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 10-10-2011, 06:28 PM   #2 (permalink)
Bdub215's Avatar
no one has a suggestion?
Old 10-10-2011, 06:56 PM   #3 (permalink)
Haters Gon Hate ;]
gr91's Avatar
Gameroom cash: $130750
View gr91's Photo Gallery
If i were you, I'd go get one from the junkyard real quick and see if it all works, mine was bad, i got one from the junkyard and bam now it works, im not sure about the speedo but the tach worked like a charm! :]
-1991 Corolla Dx - gone :/
-1992 Toyota Camry LE- Restoration Project-FAILED!
-2008 Honda Civic ex Coupe!
gr91 is offline   Reply With Quote
Old 10-10-2011, 06:57 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The VSS sends 4 pulses per revolution. Double check that you still get those 4 pulses at the sensor and at the gauge.
Old 10-11-2011, 07:05 PM   #5 (permalink)
Bdub215's Avatar
gauge works. sometimes the speedo needle will raise up to about 20mph for a split second but its usually stuck on 0. i took the two i have apart and i didnt see anything wrong with them. but i'm gonna track down a VSS this week and see what happens.
Old 10-11-2011, 07:45 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
also check the VSS wiring, any chance it could have gotten damaged while removing the old trans?
if sensor itself and wiring both check out then it's the speedo itself being at fault here?
Old 10-11-2011, 09:51 PM   #7 (permalink)
Bdub215's Avatar
I'll check over the wiring again but it looks good. I'll have to replace the sensor and go from there. Im not going anywhere near a IC. I don't have cash for that.
Sent from my iPhone using Autoguide
Old 10-11-2011, 09:59 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah, I understand. I would try another VSS too, just make sure it's designed for the trans/diff you have, they can differ a little bit (like number and size of teeth) between models.
as John mentioned, the number of pulses it generates might be different and so it can make the speedo not understand it.
