No Constant 12V power Camry '95 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2011, 11:36 PM   #1 (permalink)
View lilpenny1's Photo Gallery
WHen I open the door, the red open door light used to come on, now I have no power to radio and auto-dim mirror. Please help.
lilpenny1 is offline   Reply With Quote
Old 10-08-2011, 11:47 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
check the door ajar sensor. it could be stuck in "door closed" position.
as for power to radio and auto-dim mirror, check the fuses behind the coin holder (DOME) and maybe in fusebox under the hood too.
Old 10-10-2011, 12:17 AM   #3 (permalink)
Ok, I do hear a little humming noise when I close the door and it goes away when I open it. Where is the sensor located?
Old 10-10-2011, 02:39 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
when door is open, look at the door jamb a rubber thing with a sort of membrane.
DIY - 2000 Camry LE - Cleaning the Door/Dome Light Switch
Old 10-12-2011, 11:28 AM   #5 (permalink)
Ok, great thanks. I'll check it out.
