Help with code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2011, 04:51 PM   #1 (permalink)
View Ddizzle's Photo Gallery
Help with code
Hey i did a tranny swap on a 97 1mz camry and now im getting a code for P1765..i did the resistor setup just like ratko...what does the code mean
Ddizzle is offline   Reply With Quote
Old 10-09-2011, 08:42 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
Linear Solenoid for Accumulator Pressure Control
Circuit Malfunction (Shift Solenoid Valve SLN)
After the engine is warmed up, the current flows to the shift solenoid valve SLN for 1 sec or more under condition (a) or (b):
(a) Engine speed: 500 rpm or more
(b) Park/neutral position switch: ON (P or N position)
TROUBLE AREA
Open or short in shift solenoid valve SLN circuit
Shift solenoid valve SLN
ECM
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 10-09-2011, 09:19 PM   #3 (permalink)
Check/clean the harness on the trans. May be loose or corroded.
Old 10-10-2011, 01:21 AM   #4 (permalink)
hmm so how would i do it when my trans is manual..cause i never got a manual ecu for it
Old 10-10-2011, 11:39 AM   #5 (permalink)
If you have a manual trans with the wrong ecu then that explains the false DTC.
