Speedo Cluster questions.
okay most of you guys know im restoring a 92 camry 5sfe that has been sitting around for over 3 years. well my speedo wasnt working right, like 75% of my lights blew out, then the rpms were at like 200 when i was clearly way above that. well today i picked up a used cluster from the junkyard today. few things.
now i pulled it from a 95 -96 5sfe camry le. with 175,xxx miles. My camry has about 212,869 miles. there's no way to fix that right?
also the rpms and lights work perfect now, i idle at 700-800 like i knew it should.
BUT the airbag light came on, it happened on the old cluster before i pulled it out, so i will be checking fuses and relays but what are your guys thoughts about this?
also its pretty much all the exactly the same, i still havent tested it for the speed accuracy but im sure its good. (the old one didnt even move)
so could i get some help on how to change the mileage without it messing up and not moving the odo at all! so thanks again TN you Life savers ;]
-1991 Corolla Dx - gone :/
-1992 Toyota Camry LE- Restoration Project-FAILED!
-2008 Honda Civic ex Coupe!
