Originally Posted by kritacal88
these are 55w bulbs. does not give off any noticeable light..even against my oxidized headlights..anyone use any other type of replacement bulbs?
its probably because of the output pattern. as you can see from the picture, the fogs look way brighter than your headlamps. thats because your fogs are shooting more light up to the camera then your headlamps. since not all of the light is concentrated where it needs to be, the beam on the ground will appear weaker.
there probably wouldnt be any other bulb (thats the same connector as the current bulb) that will allow a much higher light output. if you want light output from fog lights, maybe you can get some hella projector foglights. thats what the gen4's foglights (dealer aftermarket option) are and they seem to have a pretty 'bright' output.
