Remove 5sfe head? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2011, 11:09 AM   #1 (permalink)
View nathanours's Photo Gallery
Remove 5sfe head?
Hey everyone, I was wondering how hard it would be to remove the head from my 5sfe to do a little cleaning and maybe paint it. Is this something that would be pretty hard to do, or would someone with limited mechanical knowledge be okay to attempt it?
I am guessing I'd have to wait till I'm doing an oil change so its drained right?
Here is a pic of the engine:
nathanours is offline   Reply With Quote
Old 10-14-2011, 09:41 PM   #2 (permalink)
Anyone?
Old 10-14-2011, 10:26 PM   #3 (permalink)
Haters Gon Hate ;]
gr91's Avatar
Gameroom cash: $130750
View gr91's Photo Gallery
are you talking about the valve cover?
-1991 Corolla Dx - gone :/
-1992 Toyota Camry LE- Restoration Project-FAILED!
-2008 Honda Civic ex Coupe!
gr91 is offline   Reply With Quote
Old 10-15-2011, 12:44 AM   #4 (permalink)
Gameroom cash: $122650
View 93cr250's Photo Gallery
if you need to ask, yes its too hard, unless you were talking about the valve cover
93cr250 is offline   Reply With Quote
Old 10-15-2011, 10:03 PM   #5 (permalink)
Ya sorry, I was talking about the valve cover. And I've asked about many projects and then done them myself.
Old 10-15-2011, 10:33 PM   #6 (permalink)
Gameroom cash: $101400
View oopssorryy's Photo Gallery
Unhook the few vacuum lines, and plugs, pull spark wires, and then look at the four bolt head around the holes you just pulled the spark bolts from. Find a wrench, socket, or something else to pull the boots off. Then pull head off and your done. They are wide and low and rather large..... It's really simple to take off, every thing is on top and easily visible. Just make sure to drop nothing, and keep that area clean. Don't want anything gumming up your cams.
1994 Camry LE Wagon 5S-FE with 220xxx miles.
oopssorryy is offline   Reply With Quote
Old 10-15-2011, 10:50 PM   #7 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
the spark plug tube nuts are 30mm, so borrow a 30mm axle nut socket (1/2'' dr) from autozone for easy removal and re-installation to specs (17ft-lbs).
it might be a good time to replace the valve cover gasket and 4 tube nut seals at same time.
Fel-Pro makes good gasket kits for that.
Old 10-15-2011, 11:08 PM   #8 (permalink)
There are two vacuum lines on the right side that I could see and on the left side side there is just the big clip line thing that sits between your head and timing cover. Move this to the side, the spark boots, and take those bolts off and it should come off after that. You might have to remove the top adjustment bolt in your alternator, but that's all I can think of.
Old 10-16-2011, 01:28 AM   #9 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Isn't there a DIY in the FAQ on this?
RichieRichJP is offline   Reply With Quote
Old 10-16-2011, 10:29 AM   #10 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
I was thinking the same thing as I was reading down thru this thread!
Yeah, there is. Here it is.
BMR is offline   Reply With Quote
Old 10-16-2011, 03:27 PM   #11 (permalink)
Wow I looked in the guides and completely missed it. Thanks a lot for your help guys, I appreciate it!
Old 10-16-2011, 03:33 PM   #12 (permalink)
Will I have to drain my oil before doing this?
Old 10-16-2011, 03:46 PM   #13 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Nope, no need to drain the oil.
