Almostall 90s and up Toyota's have an access panel under the rear seats. If I remember right it's under the drivers side rear seat. You'll have to remove both seat so that you can pull up the carpet. There will be small clips holding the carpet in under the door trim parts. I accidentally broke them, but no biggie. Then there will be a black cover with 5 screws and a large wire going into it. Undue the screws and gently pull the cover up the wire. Then you'll see all your fittings that go on top of the fuel pump. Then it's just a matter of disconnecting fuel lines and plugs, removing the old, and in with the new.
1994 Camry LE Wagon 5S-FE with 220xxx miles.
