Not firing up
I did a complete engine on my 1994 camry. Everything set and connectors are all in place, all sensor seems connected too but there when I start the car it crank but it wouldn't fire up. I pull the spark plug and see if its wet but nope its dry. I thought it was my fuel pump BUT I remove the fuel rail, fuel gashing out from it. So I know its not the pump. TURN OFF the light in the whole garage too see the SPARK from the plug there's no spark. Could it be the IGNITER? My timing is on the spot. And this is not the first time I swap car engine so am pretty much just confuse. Any suggestion...?
