LOL
but seriously, you can always use an oversized filter designed for more flow (or longer time).
e.g.
Oil filters:
a) 5s-fe 2.2L
PureOne standard PL14476 / larger PL14477
WIX standard 51394 / larger 51396
OEM standard 90915-YZZF2 / larger 90915-YZZF1
Mobil1 EP standard M1-103
Bosch Distance Plus standard D3311 / larger D3325
b) 1mz-fe 3.0L
PureOne standard PL10241 / larger PL20195
WIX standard 51348 / larger 51516
OEM standard 90915-YZZD1 / larger 90915-YZZD3 / 90915-20004 (JP)
Mobil1 EP standard M1-102
Bosch Distance Plus standard D3330 / larger ???
but to be honest. I think that above quote from Purolator website is just a safety valve against complains from people running dino oils (3k miles / 3mo OCI is too similar) and probably has nothing to do with actual filter longevity when using blend or fully synthetic oils in an engine which has already been cleaned up (so no sludge chunks are starting to come off and plug the filtering media).
Originally Posted by JohnGD
I guess the higher efficiency can mean the filter element begins to plug up and cause the bypass valve to open. The alternative would be something like the Fram filter, which filters 94% instead of 99.9%.
