93 camry 4 cylinder 5 sp. No start
93 Camry 5sp. 5sfe 244,xxx. New clutch at 186,xxx, new distributor 135,xxx.
just replaced brake lines. Went for a test drive, worked fine. Next morning, no start. Came back from work, started right up. Next morning started fine. But did not trust it, at that point.
Started up every morning, and night. Finally, this weekend, drove it around town. Seemed fine. The, it "bucked" once, and smoothed out. Bucked again a little more, then ran fine.
Pulled into the PO to drop off a letter, backed out, and it stalled. Would not start. Cranks fine, and "bucks" once in a while, like its way out of time, or cross firing. Had to flat bed it home.
Still will not start. Changed the igniter, no change. Sprayed starting fluid into the intake (almost a big mistake). It "puffed" out with a bang, bit of smoke, no start.
I also bought a coil, but cannot find one in the car. Perhaps it really is built into the distributor?
Anyway, I am suspecting the distributor since it has over 100,xxx on it now. But it was an aftermarket that was supposed to be lifetime, improved, blah. But, could it be?
joe a.
