Intermitant gas smell, leak!? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2011, 07:37 PM   #1 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
3rd Generation Intermitant gas smell, leak!?
This is a bit of a strange problem: It's happenend three times now, that I have started my car from fully cooled down condition, let it idle for a few seconds, and then had a very strong smell of gasoline start blowing through the air vents. I hop out quickly and find a small puddle of gas, under the car, just behind the passenger side, front wheel. I then throw up the hood (car still running), and can find no leak, but still a strong smell of gas. Take it out and drive it for a bit, and the smell fades. Park it for awhile, no puddle, no smell, for at least a couple of days! I can't find any gas lines leaking, what the.. could this be?
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 10-16-2011, 09:16 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
What area under the car? Closer to the fuel rail or fuel filter for example. Have you check the injector areas and their grommets?
Old 10-17-2011, 09:12 PM   #3 (permalink)
Domesticon Prime
It appears to drip down onto the passenger side frame rail, over top of what I think is a transmission cooler line, just behind the passenger side, front tire. A couple of checks on the top of the engine, while I'm smelling gas, show no signs of leaks around the injectors, or cold start injector. Its all dry, up top. I also haven't been able to find any sign of a leak around the area of the filter, with the car running, but the pooling appears to happen when the car is parked long enough to cool down.
Domesticon Prime
Old 10-17-2011, 09:57 PM   #4 (permalink)
View importcar's Photo Gallery
I smell gas on startup as well. I haven't checked where the leak is (if there is a leak) but no puddle on the ground like your car.
2001 Camry LE 5S-FE
importcar is offline   Reply With Quote
Old 10-18-2011, 06:14 PM   #5 (permalink)
Domesticon Prime
I know I'm reaching, but has anyone heard of a pressure regulator showing problems on occasion or full time, and forcing a leak in the fuel system? Darn thing has only happened when the car has been in places with limited light, and I have never been able to inspect all parts of the fuel delivery quickly! When I can look, its all dry.
Domesticon Prime
