Crank Shaft - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2011, 04:46 AM   #1 (permalink)
View V65rider's Photo Gallery
Crank Shaft
Hey folks I haven't posted here in a long time, I had found that my 2.2 camry had spun a bearing on the crank and had scared the crank shaft pretty bad.
I have been unable to find a motor I could afford or find a place local that I could have the crank reground.
My question is, does anyone have a crankshaft out of a spare motor that they could part with?
V65rider is offline   Reply With Quote
Old 10-17-2011, 02:03 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
If you get a used crankshaft, you need to have bearings that match it. so you will need to mic the used crank and make sure the bearings are going to work with it.
How much are the engines your looking at?
Old 10-17-2011, 05:56 PM   #3 (permalink)
I don't have a problem checking the clearances or micing and then ordering oversized bearing if need be.
The engines that I have see are between 500-1000 then you add shipping and that puts it more than the car is worth.
Old 10-17-2011, 05:58 PM   #4 (permalink)
wow that seems really extreme. most expensive engine I bought was $350.00
Old 10-17-2011, 06:39 PM   #5 (permalink)
RIBMIESTER
JimBowNut's Avatar
Gameroom cash: $134901
View JimBowNut's Photo Gallery
I'm just wondering.....Why don't you take the crank to an engine shop and have them grind it and give you correct bearings to match ?......I googled and saw 4 places in Columbus on first page of search......just wondering ?
A BLAST FROM MY PAST, MAN, THE FUN WE HAD!
JimBowNut is offline   Reply With Quote
Old 10-17-2011, 06:41 PM   #6 (permalink)
Also, isnt there a Pickandpull in Columbus? You can get crap there really cheap
Old 10-17-2011, 08:45 PM   #7 (permalink)
I actually have an email and phone calls out to a couple of the local engine shops, but figured it wouldn't hurt to see what else may be available.
I have spent a lot of time at the pick and pull for my truck and my wifes sebring but I haven't had much luck finding parts there for the toyota.
Oh and I can get motors for ford and GM all day long in the 200-300 price range but for some reason toyota motors are going for quite a bit more.
Old 10-17-2011, 08:55 PM   #8 (permalink)
in columbus, there are nine 92-96 camrys at the Pull-A-Part in Cleveland Oh in rows 200-207. There are five 97-01 Camrys at the PAP in rows 204-209. (this is for Kirby Location)
There are fourteen 92-96 Camrys at the PNP In West Cleveland in rows 107-116
There are three 97-01 Camrys at the PNP in west Cleveland in rows 107-116
http://www.pullapart.com/locations.aspx
Old 10-17-2011, 10:49 PM   #9 (permalink)
View mdemco's Photo Gallery
I just built one of these engines, I typically get used ones out of the yards around here for $500-$750 if I get the pre 97 style and retrofit the cam sensor, or 1k for a cam sensor engine with 100k on it. I planned on keeping this car so i rebuilt it to be all new,
$856 for machine shop to recondition the rods with new bolts, grind the crank, shot peen the stock pistons, mill the head, complete valve job, set lifter clearance and get rods, mains, rings and full gasket kit
$272 for a new oil pump, complete timing set and pump and pulleys, plugs, wires, air and fuel filter, pcv etc.
Built it myself, runs like a top, $1200 ish with fluids and miscellaneous, in hind sight I should have bored it, and I cleaned all my parts and what not myself, didnt even take the block in.
mdemco is offline   Reply With Quote
