98 camry bogs down on acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2011, 11:52 PM   #1 (permalink)
View chuck0591's Photo Gallery
My camry bogs down when you take off from a stop between 1000rpm -2500rpm. Ive change my fuel filter,coolant temp sensor. There are no check engine lights on. what the hell is going wrong?
chuck0591 is offline   Reply With Quote
Old 10-18-2011, 01:23 AM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Need more info. What is the mileage? Service history? What engine? Has the timing belt been done recently? How long have you had this problem?
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 10-18-2011, 09:36 AM   #3 (permalink)
141,732.(since I got the car) water pump replaced,tuned up,aftermarket air intake,transmission serviced( although I cant do a flush) the trans fluid is brick red. new coolant temp sensor,and new fuel filter.
Old 10-18-2011, 01:29 PM   #4 (permalink)
oh,valve cover gasket replaced and a current leak in rear main seal.puts off alot of smoke!
Old 10-18-2011, 01:36 PM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Originally Posted by chuck0591 View Post
...,tuned up,...
What does "tuned up" mean?.. New plugs, wires, O2 sensors, air filter?
Which engine?... V6 or 4 cylinder?
BMR is offline   Reply With Quote
Old 10-18-2011, 02:17 PM   #6 (permalink)
RIBMIESTER
JimBowNut's Avatar
Gameroom cash: $134901
View JimBowNut's Photo Gallery
Did you maybe not check your timing after the timing belt install ?
A BLAST FROM MY PAST, MAN, THE FUN WE HAD!
JimBowNut is offline   Reply With Quote
Old 10-18-2011, 02:57 PM   #7 (permalink)
4 cylinder. and just plugs,transmission serviced,oil pan dropped and cleaned,and throttle body cleaned. I brought it to toyota and the guy said the timing is ok.
Old 10-18-2011, 03:40 PM   #8 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Check fuel pressure, could be clogged cat also. You can unbolt pipe to do a quick test on that.
carsrus is offline   Reply With Quote
Old 10-18-2011, 04:33 PM   #9 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Above 2500 ok and below 1000 ok?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 10-18-2011, 05:12 PM   #10 (permalink)
i did the test where i drove for an hour and looked to see if it was cherry red. it was not.
Also yes below 1000 rpm fine and above 2500rpm fine.when i take off from a complete stop its boging down like its about to die and it feels like it cycling through gears in like 3 seconds then drops to second.best way to describe it is .... ....... ......... .......................... spaces are where the bog happenes and my foot is on the gas the whole time.
Old 10-18-2011, 06:34 PM   #11 (permalink)
I wonder if you have a dead spot in the TPS?? Can you do an OHM test on it?
Old 10-18-2011, 07:52 PM   #12 (permalink)
what is tps? and how do i do the ohm test?
Old 10-19-2011, 05:32 AM   #13 (permalink)
Throttle Position Sensor. The manual will describe the test.
Old 10-19-2011, 09:43 PM   #14 (permalink)
checked the tps.was at a 3.0 when the manual called for 3.2. so I replaced the tps still no change.
Old 10-20-2011, 05:06 AM   #15 (permalink)
I'm not sure what test you did but usually you connect the OHM meter (analog works best) and slowly depress/release the accelerator then watch for a steady and gradual increase/decrease in OHM readings. You're not looking for any one OHM value. Any interruption in resistance values would indicate a dead spot. Anyway, you replaced it and the problem is still there -
Try disconnecting the ECT after the car is warmed up and putting the engine in limp mode, then see how it runs. When it "drops to second" is that when it starts to accelerate normally?
