possible water pump leak
My water pump and timing belt were both replaced 2 years ago when my 98 Camry only had around 90K. I recently noticed that the coolant in my reservoir is a little low so I took it into my local Toyota stealership for an oil change. They claim that the water pump is losing coolant from the weep hole and it would need to be replaced. They also recommended that I replace the timing belt again at the same time. Since both the water pump and the timing belt were replaced 2 years and 18,000 miles ago, this seems a bit odd that the water pump would fail so soon. Is there another reason why my car could be losing coolant? Is it really necessary to replace the timing belt at the same time since it is only a few years old? The water pump and timing belt were replaced by an independent shop and I've been told that the warranty on the parts has expired.
I only plan on keeping this car for another year so I really don't want to fix things that aren't necessary. Any advice would be appreciated.
