1996 Camry -- Fuel pump not engaging - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2011, 08:19 PM   #1 (permalink)
View jarowe's Photo Gallery
Angry 1996 Camry -- Fuel pump not engaging
Hello all, I am new here and hoping to find some help. I have a 96 Camry LE 2.2l. the fuel pump will not engage when turning the key to the on position but does when attempting to start. Any ideas? Thanks in advance Adam
jarowe is offline   Reply With Quote
Old 10-22-2011, 01:36 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3627250
Welcome to the nation, Adam! I'll move your thread over to the appropriate Camry forum so the members there can help you out, but you should also use that forum's search feature to locate any past threads that may deal with your fuel pump issue.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 10-22-2011, 11:56 AM   #3 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
When the ignition key is turned to the ON position, you may be able to hear the PCM turn the fuel pump on briefly. For safety reasons, the PCM will turn the pump off again in a few seconds if the engine doesn’t start. When the ignition key is moved to the START position and back to ON, the PCM relies on the crank position sensor to determine whether the engine is running.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
