Driver door wire harness is shot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2011, 12:29 AM   #1 (permalink)
Micky Blue Eyes
View Mickyblue's Photo Gallery
3rd Generation Driver door wire harness is shot
Is it easy to replace? I know a junk yard where i can get one for 10$, but i have to pull it out myself, and mine is shot, both rear windows and locks dont work anymore and i know the wires are cracked/broken to peices.
What do you guys think, what should i do? I have a 96 4 door camry
Mickyblue is offline   Reply With Quote
Old 10-24-2011, 12:39 AM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Not that difficult to replace, but getting one from the junk yard is hit and miss, you could end up with the same problem or worse. Or you could get lucky and get a good one. Easy way to tell which wires are broken is to unwrap the harness, and pull on each wire, usually the bad ones pull right out. you can then solder in a new section of wire.
The way I repaired mine is I got a harness from the wreckers, cut my harness off a couple of inches back where the wires bend, then soldered in the donor harness using the part that does not bend. It was a lot of work because I had to solder every wire not only in the middle part of the harness, but also at the connectors. You can do the same thing I did, but only replace the wires that are broken, will save a lot of time. What I did was probably overkill but I'm guaranteed the harness will last for the life of the car because all the stressed sections of wire have been replaced.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 10-24-2011, 12:43 AM   #3 (permalink)
Micky Blue Eyes
thats what my toyota mechanic told me, but i know how bad mine is already and i promise you one from a junk yard cant be as bad as mine, i mine, mine has wires missing, well basically 15 years and 237k miles of constantly opening and closing that door.
Is there another way of repairing the wires without sodering? How about the electrical crimper things?
Old 10-24-2011, 12:48 AM   #4 (permalink)
71Corolla's Avatar
Crimping is not the best method IMO, prone to failure and they take up a lot of space, if you have 10-12 of them the harness will be huge. Take a look in the salvage yard, you might find a good harness, unwrap the electrical tape on the connector side (kick panel/fuse block) far enough to where it exposes the one end of the rubber boot. Then pull on each wire with needle nose pliers to find any broken ones.
Old 10-24-2011, 10:07 AM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
Yeah, I'd stay away from those crimp-on splicers. Best to solder and shrinkwrap those joints. They take a beating in that door hinge area.
BMR is offline   Reply With Quote
Old 10-24-2011, 05:10 PM   #6 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Another way to seal the joints besides using shrink wrap is using the liquid electrical tape. Just make sure the surface isn't all grimed/greased up...
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 10-25-2011, 01:46 PM   #7 (permalink)
Micky Blue Eyes
Okay. I'm mainly worried about how to access the wire harness on each connectors end. And pulling it out of the door. Is there any tricks to doing this
Old 10-25-2011, 05:14 PM   #8 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Pull it through the body to the door. It should pull right through.
If I were you ide cut the loom apart and, slide some shrink tubing over the wire, and Solder the broken wire(s). Then tape the harness back together and pull it back through the door.
/done
