94 v-6 help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2011, 03:53 PM   #1 (permalink)
View 99stangvert's Photo Gallery
94 v-6 help
hi everyone new to the nation and to toyota cars. have a 94 v-6 that just stoped running while driving. has fuel because can smell while cranking. dont have any spark. grounded just like chiltons says to do . tested crank sensor tested good , tested cam senson tested good. any help would be great thanks
99stangvert is offline   Reply With Quote
Old 10-24-2011, 04:21 PM   #2 (permalink)
View tbalon's Photo Gallery
Sounds like a bad coil.
tbalon is offline   Reply With Quote
Old 10-24-2011, 04:30 PM   #3 (permalink)
checked front three coils (has distributorless ing.)front three dont fire
Old 10-24-2011, 05:15 PM   #4 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Did you check the ignitor? Fuses checked?
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 10-24-2011, 07:12 PM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
yup, BamZipPow is right.
if it has 3 front coils on top of spark plugs and no distributor then it should have an igniter, I think on the driver side by the strut mount (by air box). 1mz-fe engine, isn't it?
you should also check resistance of both primary and secondary circuits of those front coils, unlikely that all 3 went bad (out of specs) ... but it's possible too.
don't forget about all the fuses too
