Rear speakers are a PITA to get to, really. You pretty much have to remove the sides from rear seats, which will allow you to remove the rear side covers (the ones b/w windows and rear doors), which will then allow you to remove the back panel, giving you access to the speakers.
To make matters worse, Toyota doesn't really use standard speaker sizes, from what I hear, so fitting aftermarket speakers is not just a straight bolt-on.
As for your CD, you could try to give the old deck 12v, and see if it comes to life? Somebody correct me if that doesn't work.
Hope this helps.
