Recommendations for mismatched headlight bulbs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2011, 02:39 AM   #1 (permalink)
View fighting69's Photo Gallery
Hello all,
My wife's parents recently gave her their old 1994 Camry LE. I have been tasked with doing some very basic maintenance and cosmetic repairs. When I went to install new lowbeam headlight bulbs I ran into a problem. The passenger side was easy but I discovered that the driver side had a 9005 HB bulb installed. Both the connector and the retaining ring the bulb screws into are for a 9005 bulb.
Is driving around with a 9005 HB bulb on one side going to bother oncoming traffic? If so is there a fix that does not involve purchasing a new headlight? If 9005 as lowbeams are okay should I try to put a 9005 bulb on the passenger side so the bulbs match?
Thanks for any insight you are able to offer.
fighting69 is offline   Reply With Quote
Old 10-26-2011, 12:41 PM   #2 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
what is it supposed to be ?
sit the car a bit from a wall/garage door and see if the light scatters all over or if the light looks like it has a good pattern. if it has a good pattern, then dont worry about it unless ur ocd and really want to fix it
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 10-26-2011, 02:41 PM   #3 (permalink)
Gameroom cash: $303755
Just in case you don't have the owner's manual to determine what the correct bulb should be, you can use this site. I print out the page for all my cars and keep it in the glove box.
http://www.sylvania.com/ConsumerProd...lacementGuide/
Mike
Old 10-26-2011, 02:42 PM   #4 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Running both 9005 is ok. Thats what I'm running in my camry right now for low beams. Helps you see at night better
