Fitting a 2.5" muffler to 1.7" pipe?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2011, 12:27 AM   #1 (permalink)
View Pandalizer's Photo Gallery
I have a 98 camry with 1mzfe. I got a muffler the other day, but the inlet on it is 2.5"
My problem is that the exhaust pipe on my camry is 1.7" or 1.75"
Im not sure if it is the stock piping or not, because it seems really small.
So, i was wondering, how would i get the new muffler which has a 2.5"
inlet to fit on my 1.7"(or 1.75") exhaust piping?
Thanks
Pandalizer is offline   Reply With Quote
Old 10-28-2011, 12:33 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
the stock piping is 2.5"i believe. your piping is waaaaay too small. replace the entire exhaust system from the manifold back if this is the case.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 10-28-2011, 12:43 AM   #3 (permalink)
Uuugh. I hoped that this wasn't the case. Why would someone put such small pipes on it?? It might just be from the cat and back because the exhaust manifold looks like it's stock.
Old 10-28-2011, 07:31 AM   #4 (permalink)
Site Owner
View Ahil's Photo Gallery
stock 4cyl gen4 piping is 2" diameter
Ahil is offline   Reply With Quote
Old 10-28-2011, 07:44 AM   #5 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
Stock diameter is 2" but your gonna need to get it welded on at an exhaust shop. There is no good way to clamp the exhaust together.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 10-28-2011, 10:05 AM   #6 (permalink)
well i have a 6 cyl. but i can weld it on myself. i have a mig. But i just don't know how to go about doing it.
Old 10-28-2011, 11:27 AM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
First of all ya gotta make sure your materials are similar. Second youll need reducers. As long as it is a steel to steel it should be pretty easy. you have to start by making some tac welds to get it in place. Then just go from there. Personally just weldin on a muffler is more work than its worth unless u know what your doin. Shops dont chaege much and they can get it right the first time.
R.I.P.
Car Domain:
Old 10-28-2011, 02:43 PM   #8 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
^what he said. get a reducer. make sure u line everything up or it'll look like ish
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 10-28-2011, 03:28 PM   #9 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Your biggest problem will be burn through on thin wall pipe. You'll need to stitch weld it to avoid too much heat melting the pipe. Take your time and use smallest wire you can get to reduce amp/heat output. You'll also need to remove the exhaust pipes to get access all around the pipe and to avoid welding overhead.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 10-28-2011, 11:37 PM   #10 (permalink)
Okay, guys, i just went to the local muffler shop today. They cut off the existing muffler and also about 2 feet of piping attached to it.
then they just welded larger piping and the new muffler on it. It cost me 45 bucks, but it's well worth it. The new one sounds deep, but not like a fart can.
Ahah i was so happy. I'll post pics of it soon
