Parking Light Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2011, 05:42 PM   #1 (permalink)
Corolla Screamer
l4zy415's Avatar
View l4zy415's Photo Gallery
Question Parking Light Problem
Hey guys, I'm having a bit of a problem. I just installed an alarm system on my mother 97' Camry LE 4-cyl. The parking lights blink when I hit the lock and unlock from the keyswitch. But if I try to turn on the parking lights using the steering toggle switch, it does not turn on. Not even the interior lights like the cluster or shifter light turns on. Headlights comes on fine, but not the parking lights. Do you guys think I messed up a wire for the toggle switch or is there a relay I messed up? I appreciate the help I can get from you guys, thanks.
l4zy415 is offline   Reply With Quote
Old 10-30-2011, 08:48 PM   #2 (permalink)
Corolla Screamer
l4zy415's Avatar
Damn, 55 views and not a single help? Well does anyone know a good website to get wiring diagram?
Old 10-30-2011, 10:14 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Probably something simple like you accidentally unplugged a connector. Also make sure you check and double check all your fuses.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 10-30-2011, 10:55 PM   #4 (permalink)
Corolla Screamer
l4zy415's Avatar
Fuses are fine and everything is plugged in. There is one thing I forgot to put in. While I was trying to wire up the parking light wire for the alarm system, I accidentally wired it to a 2 pin plug that sits under the fuse box. its next to the orange plug if you guys ever seen it. So, I'm wondering if i fried that one wire by accident or something. It was working before i did that wiring part. I'll give it another look tomorrow since its dark right now.
