'93 Camry LE, some of the rear defroster wires don't work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2011, 06:59 PM   #1 (permalink)
Gameroom cash: $872000
View zb420's Photo Gallery
Is there an easy fix?
Thanks
1993 Camry LE 2.2l
Original owner
112k mi.
zb420 is offline   Reply With Quote
Old 10-30-2011, 07:06 PM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Easy fix? NO.
The lines have been damaged by contact with the glass or possibly overzealous glass cleaning over the years. Some glass companies will repair one or two defroster lines for a fee.
Zembonez is offline   Reply With Quote
The Following User Says Thank You to Zembonez For This Useful Post:
zb420 (10-31-2011)
Old 10-30-2011, 07:32 PM   #3 (permalink)
View 97ToyCar's Photo Gallery
4th Generation Re: Defroster Wires
All is not lost. Most auto parts stores and places on the internet sell a defroster repair kit. You can do it yourself. The kit comes with a glass vial of conductive paint with a built in brush, and a template that you use to recreate the lines on the glass.
Basically, to find the break in the wire, can do it 2 ways. Either look visually to see where chunks of the defroster grid are missing, or you can use a voltmeter to find the break.
Here is a helpful link.
http://autorepair.about.com/cs/doity...a112302a_3.htm
Good Luck! Try to DIY it if you can, a replacement window with grid is NOT cheap. The grid is baked to the glass during manufacture.
Dave
97ToyCar is offline   Reply With Quote
The Following User Says Thank You to 97ToyCar For This Useful Post:
zb420 (10-31-2011)
Old 10-30-2011, 10:31 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
See also:
http://www.popularmechanics.com/cars...enance/4221212
And repair kit:
http://www.permatex.com/products/aut...Repair_Kit.htm
The Following User Says Thank You to JohnGD For This Useful Post:
zb420 (10-31-2011)
Old 10-30-2011, 10:49 PM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
I've done this repair numerous times using that Permatex kit JohnGD posted a link to. It works well. The hardest part can be finding the scratch across the defroster gridline. It doesn't take much of one to break continuity. And make sure the glass is squeaky clean; wipe it down with rubbing alcohol to get all the contaminants off so the paint will adhere properly.
BMR is offline   Reply With Quote
Old 10-31-2011, 11:09 AM   #6 (permalink)
A few of the lines still work OK.
I'll take a peek at the grid this a.m. when I go down to the car.
1993 Camry LE 2.2l
Original owner
112k mi.
Old 10-31-2011, 12:12 PM   #7 (permalink)
Could the ppl that tinted the windows contributed to this problem?
1993 Camry LE 2.2l
Original owner
112k mi.
Old 10-31-2011, 01:51 PM   #8 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Ooooo... you didn't mention that the windows were tinted. Yes, it's possible they damaged it. But if they're experienced at it, it shouldn't happen. Is this the type where there's a plastic film applied to the inside? If yes, the tinting film would have to stripped off first to permit repairs to the gridlines. I've never done it, but I'd guess it ain't easy.
Old 10-31-2011, 01:56 PM   #9 (permalink)
Originally Posted by BMR View Post
Ooooo... you didn't mention that the windows were tinted. Yes, it's possible they damaged it. But if they're experienced at it, it shouldn't happen.easy.
Yes, they are a very well known business locally that some of the major auto sellers use too.
1993 Camry LE 2.2l
Original owner
112k mi.
Old 10-31-2011, 02:04 PM   #10 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
That's good. Do you know if it was working before they installed it? Those gridlines are quite fragile. Just tossing a jacket back there with a metal zipper can scratch thru them. So it's possible they damaged it without knowing it... stuff happens. It might be worth your time to go talk with them; maybe they have methods of removing it easily?
Old 10-31-2011, 02:20 PM   #11 (permalink)
I think it was working just about the same.. It just wondered what this would entail?
1993 Camry LE 2.2l
Original owner
112k mi.
Old 10-31-2011, 05:22 PM   #12 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
you'll have to remove the window tint in order to test the grid and repair and sections that may be losing resistance.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
The Following User Says Thank You to mazdaverx7 For This Useful Post:
zb420 (10-31-2011)
Old 10-31-2011, 06:17 PM   #13 (permalink)
I'll get by... I live in SoCal....
Are winters aren't like the east coast...
1993 Camry LE 2.2l
Original owner
112k mi.
Old 11-01-2011, 02:17 AM   #14 (permalink)
mazdaverx7's Avatar
being in southern california, you shouldn't have too much of a need for it other than on chilly mornings or rainy days.
85 RX-7 GS 5spd
zb420 (11-01-2011)
Old 11-01-2011, 11:48 AM   #15 (permalink)
Figuring It Out
RedAliCat's Avatar
View RedAliCat's Photo Gallery
4th Generation
Oh, dear. I'm the 5th owner of a 97 LE, and it appears that there had been tint on the back window, then someone decided to remove it--and not very well. Some is still on, and much remains on the grid lines. Of course it's not working, but this wouldn't be a simple, one-line break, I'm guessing.
Is my only option to replace the entire window, considering the extent of the tint removal problems? Any other (cheaper) options?
1997 Camry LE
4-cyl, 2.2L 5SFE, 195k, 5th owner
RedAliCat is offline   Reply With Quote
