front seals leaking oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2011, 02:45 PM   #1 (permalink)
View camryowner25's Photo Gallery
When I took my 1998 Camry in for an oil change, the technician told me that my front seals appear to be leaking oil. The seals that are leaking are located near my timing belt. All of the seals in this area were supposedly replaced when my timing belt and water pump were replaced 15,000 miles ago. Is it possible that the seals were installed incorrectly? Or could the oily substance be power steering fluid? (My car has been leaking power steering fluid for years.) The only substance that I have noticed on the floor of my garage is power steering fluid so I am skeptical about this recent discovery. How can I tell if this guy is telling me the truth about these leaking front seals?
camryowner25 is offline   Reply With Quote
Old 10-31-2011, 02:55 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Anything's possible. Take it back to the shop that did the timing belt.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 10-31-2011, 05:24 PM   #3 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
remove the timing cover and check for yourself. that's really the only way to properly inspect the area. i don't let anyone work on my cars because of hack mechanics and lying to the customer. the seals that would be leaking could be the front main seal or the cam seals.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 11-01-2011, 07:56 AM   #4 (permalink)
View eevee11's Photo Gallery
When you say "front main seal" is that the same as the oil pump seal?
99 Camry V6 LE, 80k miles
eevee11 is offline   Reply With Quote
Old 11-01-2011, 12:13 PM   #5 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
is your car dripping oil where its parked overnight?
i would take a technician's recommendation with a grain of salt. i think most get a bonus if they convince vehicle owners to get unnecessary work done at their shop. if you want to check things out, spray some degreaser on the bottom of the engine and see if new oil leaks down after a couple of days.
Old 11-02-2011, 12:35 PM   #6 (permalink)
View deejayphilo's Photo Gallery
I did my friends car because his mechanic told him same thing which charge him $1200 gor a $15 from crankshaft seal. If you did your timing belt nt too long ago he could just recommend replacing the front seal for free depending on the mileage of the car. Popping the front seal is not that hard. Removing the crank sprocket is suppose to be as difficult as I thought. But then that sprocket get stucked there. I have to drill 3/8 hole close to the shaft and forced fit a nut and used my puller. That sprocket is not that expensive too. Its just pain removing it.
deejayphilo is offline   Reply With Quote
Old 11-02-2011, 12:37 PM   #7 (permalink)
Seal you can get at autozone which is $15...and the sprocket is $30
Old 11-02-2011, 01:16 PM   #8 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $149050
View hardtopte72's Photo Gallery
Sounds to me like a power steering leak being misdiagnosed. On the same note it could be incorrectly installed or not all seals replaced. On a 5sfe there is a cam seal, crank seal, oil pump seal, oil pump oring, and valve cover gasket that can leak on the front. One a 3vzfe or 1mzfe you have 2 cam seals, 1 crank seal, valve cover gasket that can leak in front. Did you replace all seals when you did the belt or just the crank. All questions that need to be asked. But agai. It is most likely a misdiagnosed power steering leak.
hardtopte72 is offline   Reply With Quote
