Originally Posted by ghettosled
im about to order these parts for my car over the weekend. i can let you know because the only link that really needs replaced is the driver's side front which requires removing the bolt.
to my understanding, you have three choices:
1. drop the rear sub frame.
2. cut the bolt.
3. drop the fuel tank.
since my car is more rust than metal underneath, i dont think i can drop the rear subframe without shearing bolts. i dont want to cut the bolts because i dont know how difficult it would be to find replacements. so im planning on dropping the tank. if the bolts holding the straps do shear, i dont recall it being to difficult to access in order to drill and tap new holes.
I found it easier to drop the sub-frame than the gas tank because i didn't want to risk breaking one of the lines and i had a full tank of gas lol. if you decide to drop the sub-frame make sure to heat up the stud nuts and lightly wiggle them back and forth, and apply PB blaster or ecuivalant before trying to fully loosen them or they WILL break the stud off ha-ha i found that out the hard way even only by applying a small amount of torque just to see how tight they were, POP! ha-ha. lucky the dealership in my town had a set of new studs in stock so i replaced all four studs and cushion mounts. if you do decide to go for the sub-frame and break a stud they are $3.61 Part# 9010910143 from the dealer, i got mine from PAGE TOYOTA they are a dealer out of Southfield Michigan and you can order the part from their web site which is
http://www.toyota-parts-dealer.com/
