1998 Camry down to 2 cylinders??
Hey all, I've got a 98 Camry 5S-FE and she's not in good shape. It started out with rough idle and hesitation, then it happened. One day I was started out down the road and something seemed weird. Car was revving higher than normal and by the time I got to the interstate I realized that the check engine light was flashing at me. So I pulled over before I messed anything else up.
Well I got the codes and it turned out to be a P0302 and P0303, misfire on cylinders 2 and 3. So the first thing I thought was a bad ignition coil as one coil fires 2 and 3. So went down to the parts store and got a new one. Well I replaced it and no dice. So I got all new plugs, still no dice. The wires are only like a year old so I just don't think it's the wires. I also swapped the 1, 4 coil with the 2, 3 coil to see if it would fire but it doesn't.
When it fires up I can smell a strong gas smell so I know it's getting fuel and just not spark. Any ideas guys? I'm wondering if it's the ignition module, but don't know much about it or how to test it.
Any help would be greatly appreciated. Thanks!
Brad
