door sensor things not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-05-2011, 05:04 PM   #1 (permalink)
Gameroom cash: $122650
View 93cr250's Photo Gallery
those little buttons that tell if the door is closed or not are not working on the 2 back doors, so when you open the back doors at night, the dome light wont come on which can be annoying. Can these be fixed, or do i just need to buy new ones?
93cr250 is offline   Reply With Quote
Old 11-05-2011, 05:27 PM   #2 (permalink)
Tech1984's Avatar
Gameroom cash: $254350
View Tech1984's Photo Gallery
Those are called courtesy switches. You may be able to get them working again by pulling the rubber boots back and spraying some electronics cleaner directly in there at the button.
Keep working them and they may start popping on again.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline   Reply With Quote
Old 11-05-2011, 06:23 PM   #3 (permalink)
2001 Camry XLE 1MZ-FE
View ajkalian's Photo Gallery
Here's how to fix 'em.
DIY - 2000 Camry LE - Cleaning the Door/Dome Light Switch
2001 Camry XLE, 6cyl, 1MZ-FE, 91,000 miles.
ajkalian is offline   Reply With Quote
Old 11-05-2011, 07:25 PM   #4 (permalink)
Originally Posted by ajkalian View Post
are they the same for the 92-96's?
Old 11-05-2011, 08:03 PM   #5 (permalink)
Don't know for sure. Take one of yours apart and see what the differences are, if any.
Old 11-06-2011, 05:35 AM   #6 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
^^++++ Yes, do that first and save yourself a lot of hassle. Worked for me and still working 3 years later. Cleaner with lube is good.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-06-2011, 11:14 AM   #7 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
I hosed mine down with WD40 a few years ago; still working well. I suspect almost anything will work. Just need to flush out all the dust. Mine were filthy dirty.
BMR is offline   Reply With Quote
