Abs DIY repair - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2011, 02:14 AM   #1 (permalink)
View camrycraig's Photo Gallery
4th Generation Abs DIY repair
I have a 2000 V-6 5 speed. The drivers side rear brake doesn't seem to work. There is rust on the disk. I am wondering if there is anything I can do to troubleshoot the ABS system. I can't find any info on this in the Haynes manual or on this forum. If you have any info on this I would appreciate the help.
camrycraig is offline   Reply With Quote
Old 11-06-2011, 03:52 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
if the disc surface is rusty where the brake pads should make contact you could have a frozen caliper piston or a caliper slider that's stuck. the only option is to pull the caliper off and inspect it and the slider pin for rust and wear. if you replace one caliper, i reccomend replacing the other caliper, the pads, and the rotors. do it all at once and save furure headaches.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 11-06-2011, 08:15 AM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
The ABS sensor is just a magnetic pickup that picks up the signal from the hub Ring.
If your ABS light is on, take the brake assembly apart down to the ring/pickup and clean them with brake clean. That typically solves the problem.
If your brake isnt holding when you push the pedal, more than likely the post above is the problem
Old 11-06-2011, 10:13 AM   #4 (permalink)
There is no problem with the caliper as I replaced the pads and inspected the caliper recently. I am concerned about the equalizer in the engine bay. I can't find any info on it.
Old 11-06-2011, 10:22 AM   #5 (permalink)
Is your ABS light on?
Im gonna PM you in a second..
Old 11-06-2011, 09:18 PM   #6 (permalink)
No light, but with that other info I am sure that I can figure it out. Thanks again.
