Originally Posted by Stillrunning
I think we got a "who's on first" thing going on here.
The OP didn't say what motor he has, and it makes a difference, a big difference.
Here's a shot of what the motor mounts look like on a 2000 1MZ-FE, 6cyl. The back motor mount doesn't look anything like the 4cyl version. The motor mount (12321-A) does house the axle carrier bearing as well as the rubber motor mount (12371-A), and all of that bolts to the frame and the back of the engine. It's a real PITA to get to, and to change out the rear motor mount in a 6cyl.
You have to remove the passenger side wheel, then unbolt the axle, remove the axle from the wheel bearing/brake assembly. Then remove the axle from the carrier bearing, then unbolt the housing from the frame and the rear of the engine. Then press out the old rubber motor mount, and press in the new one, and re-assemble everything.
The engineer that designed that should be serving 5 years to life.
