my new camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2011, 08:49 PM   #1 (permalink)
View Zain's Photo Gallery
my new camry
hey guys i upgraded from a 97 corolla to a 2001 camry LE 67k
not a major upgrade but i am already loving the car.
a couple of things i was asked to change
automatic transmission fluid is very dark needs to be changed
power steering fluid need to be changed
oilpan gasket is leaking(its making me worried)
any help would be appreciated
he also said that struts need to be replaced also but not now
and yeah the front tires needs to be replaced
[IMG][/IMG]
Zain is offline   Reply With Quote
Old 11-07-2011, 08:52 PM   #2 (permalink)
the car is dirty
cabin and engine bay needs cleaning
i might not clean the engine bay since its getting cold and i dnt wana take risk with leaving water on the engine
i really wana swap the odometer lights with white and red leds
i saw a thread about the needles colors
but i am not sure about what size leds should i use.
Old 11-07-2011, 09:17 PM   #3 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
Love the wheels. Same as mine
You can checkout the DIY section for help. But here the links.
Transmission Fluid Change: DIY: 5S-FE Transmission Fluid & Strainer Replacement Procedure
Power Steering Change: http://www.toyotanation.com/forum/t19334.html
The oil pan is a simple drop and this engine should use a gasket. Drain the oil, remove the pan, clean off old gasket, oil pan, and mounting surface of engine block, install new gasket with some RTV or Hondabond, reinstall it, and fill it up with fresh oil.
The gauge cluster uses 194 bulbs. Four or six of them I think.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 11-08-2011, 08:35 AM   #4 (permalink)
i love the color of your car, i wish mine was black
anyways what foglights did u use?
i was planning to put hids in my fog, but thats for future
also what other mods have you done to your car?
about gasket
i don't want take risk with the gasket. ill just let my mechanic do it for me
also about the oil change what kind of oil is used in this car
i would put 5w-30 in my corolla
Old 11-08-2011, 11:29 AM   #5 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
5w30 will work in ur camry as well.
Looks like a nice ride.
Check out the DIY Articles for how to drain the transmission and other useful information.
Old 11-08-2011, 01:28 PM   #6 (permalink)
about oil, ive been using the mobile one oil for my corolla
but since i will be replacing transmission and powersteering fluid also
which one should i go with
i see alot of people use Royal purple
i wont mind paying extra for them but i dnt know how good they are?
Old 11-08-2011, 01:43 PM   #7 (permalink)
on full afterburner
Gameroom cash: $1340197
Mobil 1 > Royal Purple
Old 11-08-2011, 01:47 PM   #8 (permalink)
Yuko's Avatar
about gasket
Thanks. Black is nice color but a pain to keep clean. I spent 6 hours with the clay bar, buffing, and waxed my car over the weekend. Then it rain today....
The fog lamps I used was the "Driving Light Kit" from Walmart. I think it cost about $25 now. Autozone and Oreilly's carry similar product. It has a glass lens and metal case. The problem is that because they are mounted behind the bumper cover, it's not as bright. They are more like DRLs.
I also convert the rear drum brakes to discs which improved stopping. It's in the DIY section. But I spent most of my time fixing the Camry.
DIYs thread: Camry FAQ ------> READ FIRST -----> Comprehensive List of Gen 3/4 INFO and DIY
^look through it was there are many good Mods.
As for the oil, 5W-30 is fine as Perkins stated.I use Valvoline Maxlife but Mobil 1 is perfect. I haven't use Royal Purple so I can't speak for it. Just remember to use a good oil filter like Wix or Purolator.
Old 11-08-2011, 11:45 PM   #9 (permalink)
does camry have transmission filter?
i asked my mechanic and he said camry doesnot have transmission filter
anyways i will be doing my power steering and transmission fluid flush tomorrow
Old 11-09-2011, 12:30 AM   #10 (permalink)
Yuko's Avatar
Your Camry doesn't use a filter, just a metal screen.
Old 11-09-2011, 08:28 AM   #11 (permalink)
ohh okey,
thanks for all the info guys
Old 11-11-2011, 01:46 PM   #12 (permalink)
hey i had my transmission, power steering and engine-oil flushed yesterday
now i was driving my car and i dint noticed the AC
like i turned my ac on. and the knob will only blow air when its on high(full)
on the first 3 levels it doesnt even blow it,
what could be wrong with this?
do i need a new AC control?
Old 11-11-2011, 01:56 PM   #13 (permalink)
Gameroom cash: $872000
View zb420's Photo Gallery
Mom has a Camry ('01) simialr to yours.
I believe it has the same wheels.
Her car is the Gallery Edition but with leather interior.
http://www.intellichoice.com/1-12-20...-packages.html
It's a very sold car, a great year for Toyota... 2002, NOT SO GREAT!!!
1993 Camry LE 2.2l
Original owner
112k mi.
zb420 is offline   Reply With Quote
Old 11-11-2011, 02:19 PM   #14 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
So the blower (fan) motor only runs on high?... none of the lower speeds work? That's probably the fan resistor pack. Here's a DIY showing how to fix it.
BMR is offline   Reply With Quote
Old 11-11-2011, 02:41 PM   #15 (permalink)
http://www.partstrain.com/store/deta...26011101blmore
this is something i would need i guess
and where exactly is it situated
like under the glove compartment or right behind the ac knob?
