Timing belt saga...Dealer says lower end is gone? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2011, 09:08 PM   #1 (permalink)
View grahams98's Photo Gallery
Timing belt broke on 2000 Camry 2.2. So I read up on this forum and brought in a mechanic buddy as didn't think I was up to the task. We get everything off and go to line up the mark on the balancer but encounter resistance turning the crank as we're trying to line it up the zero degree mark. My buddy talked with the dealer today and they said that it's most likely that the lower end of the motor (crank,etc) is gone/going and that is what likely the cause of the timing belt breaking. We're going to drop the pan tomorrow to inspect but I'd love some informed advice.
BTW: we removed the plugs to be sure that it wasn't just compression resistance.
BTW2: It's at 187,000 miles so I thought I could more life on this one.
grahams98 is offline   Reply With Quote
Old 11-07-2011, 09:46 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Timing belt breaking should not cause problems except stranding. You'd read plenty owners had that. But the belt might have snapped because of the resistance problem. So pull the pan and inspect. See what might have seized up.
Old 11-08-2011, 07:31 AM   #3 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Oil pump could have gone to crap and eaten up the timing belt.
Its highly unlikely but possible. If you were doing high rpm for a while before the belt broke its possible. When the belt starts to tear and rip b/c of something seizing the oil pressure drops.
carsrus is offline   Reply With Quote
Old 11-08-2011, 10:29 AM   #4 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Seeing all the rotational force comes from the crank, I can't think of a way a lower end engine problem would cause a timing belt to break. Maybe the balance shaft assembly is failing and causing the crank to jump?
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 11-08-2011, 10:57 AM   #5 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
+1, the timing belt is turned by the crank, so any resistance on the crank itself would only cause damage to other internal parts, there would be no effect on the timing belt itself.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 11-08-2011, 11:25 AM   #6 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
pull all the spark plugs and try to rotate the engine. With the spark plugs installed, the compression cannot escape easily. With the plugs removed, should rotate relatively easy.
Old 11-08-2011, 12:03 PM   #7 (permalink)
Thanks, we will give that a look as well. The spark plugs are out and we only encounter resistance turning the crank as it nears the zero mark. We are going to inspect the other pulley that's turning along with the crank and see if something else is obstructing free movement. We are also going to drop the pan if that fails.
What the dealer mechanic said is that since the only connection as far as turning force goes is the timing belt that the top end will continue to spin after the bottom end seizes which will cause the belt to break. My wife was just pulling the car out of the driveway and was accelerating up to speed 50 feet from where it was marked overnight. It's pretty likely that she didn't warm it up thoroughly since she do great at that but she didn't hear any of the thumping normally associated with lower end crank issues.
Old 11-08-2011, 12:13 PM   #8 (permalink)
Well, driving the car cold will likely not cause the belt to break.
There must be another problem, With the belt off, spin each pulley and see if one of them makes noise or has excessive play. All the pulleys should be tight and not turn very easily. Even the idler pulleys and tensioner pulley.
Old 11-08-2011, 04:02 PM   #9 (permalink)
checked everything else externally and then dropped pan. Something is clanking when we turn the crank manually but can't see exactly where. Please direct me to any threads that would help.
The lower end of this engine has a lot going on in there and it has been years for me.
Old 11-08-2011, 04:14 PM   #10 (permalink)
I'de drop the engine balacer, then you can get a better picture of whats going on.
Grab each connecting rod and move them around.
Did you have any metal pieces in the pan?
The Following User Says Thank You to Mister_Perkins For This Useful Post:
grahams98 (11-08-2011)
Old 11-08-2011, 05:09 PM   #11 (permalink)
There's is some brass in the pan not huge chunks but not good...
Old 11-08-2011, 05:21 PM   #12 (permalink)
small particles, in dust form is OK in a small amount. If you have large pieces such as 1/8" thick or larger, you've got a problem.
Old 11-08-2011, 05:31 PM   #13 (permalink)
Nothing that large, but larger than I would have liked to have seen. Maybe 1/16th thickness with a total volume of the metal in the pan equal to roughly a 1/4 to 1/2 teaspoon (mostly dust).
The Haynes Manual is really adamant that the balancer is a no-touch zone...is it okay to pull that out as long you don't remove anything else?
Old 11-08-2011, 05:36 PM   #14 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
If the bottom end locks up at speed, it's entirely possible for the inertia of the top end components to shear a timing belt. Obviously you are on the job already checking the lower end. The brass in the pan is not a good sign at all.
Hope it comes out favorable!
Zembonez is offline   Reply With Quote
Old 11-08-2011, 05:40 PM   #15 (permalink)
Yeah you can remove the balancer. Just make sure the bottom end is TDC before removing it, and use a paint marker to mark the balacer off.
If you look on the one side of the balancer, you can see it has a couple Circles on the outside. This houses a gear assembly on the inside of it that helps dampen vibrations from the engine. Mark off Vertically (From the case of the balancer, onto the Circles that connect to the gears inside). Once you mark them off, simply disconnect the oil pickup, and remove the bolts for the balancer. It will drop out and two shims will fall out too. Make sure to mark off what side and the direction they come out.
When installing, make sure the balance cams are lined up, place the shims ontop and install the bolts.
With that much dust, that's really not a good sign though.
