Preheater for 3rd gen - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2011, 07:32 AM   #1 (permalink)
View steve76's Photo Gallery
Anyone using a preheater for a Camry here? I've just found a thread on this. So we can skip the block heater. Then a water heater that uses the temperature difference of liquids to circulate the coolant? Anyone done this?
Thanks!
steve
steve76 is offline   Reply With Quote
Old 11-08-2011, 08:54 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Originally Posted by steve76 View Post
Anyone done this?
Yes, useless. Not enough heat generated to compensate for cooling of so-called "circulation". Block heater with 0W - XX oil is still best choice.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-09-2011, 04:03 AM   #3 (permalink)
What product do you recommend? Does a Toyota OEM one exist? I see in threads that for the 5th gen, it wouldn't be a problem. For the 3rd gen, who knows? Is there a plug for this in the block, or the rfost plug is the only one?
steve
Old 11-09-2011, 09:57 AM   #4 (permalink)
Can't speak for V6 but I4 has frost plugs in front for access. I'd buy best block heater you can as installation labor will be most of time/expense. I'd also look at timer as I doubt you need it on all night.
