What struts to use? Tokico or KYB on 97 V6 Camry ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2011, 12:17 PM   #1 (permalink)
View Tukkus's Photo Gallery
I was wondering if there is that much of a difference between the 2 struts that I should take in to consideration before I choose.
The Tokico is more expensive but I know zero about struts and want to know if they are going to make a difference in the ride.
I have a friend that has a lift so we will replace the struts ourselves.
Tukkus is offline   Reply With Quote
Old 11-08-2011, 12:20 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Search, search, search will answer your question Grasshopper.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-08-2011, 01:48 PM   #3 (permalink)
Doing a search gets me this message..... "all remote agents unreachable and no available local indexes found"
Old 11-08-2011, 01:56 PM   #4 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Go with KYB if you're not lowering.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
Old 11-08-2011, 06:56 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1340197
This.
Old 11-08-2011, 08:59 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Are you set on either one of those? Or maybe price out the Monroe QuickStruts from rockauto or Amazon if you need new mounts or other parts. Or try Monroe OESpectrum struts. All carry lifetime warranty.
The disadvantage with KYB is that they don't cover normal wear and tear.
Old 11-09-2011, 02:05 AM   #7 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $589157
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Tokicos are sportier and a bit firmer than KYBs which are similar to OEM factory. Actually, they are OEM-similar.
Tokicos are only worth if you're lowering, but if you're not and still want some sort of firm drive and handling, Tokicos are good to go. Plus, if you're planning on lowering in the future, you don't need to worry about replacing shocks, unless you go for coilovers.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 11-09-2011, 04:22 AM   #8 (permalink)
Tom 2000's Avatar
Gameroom cash: $201200
View Tom 2000's Photo Gallery
I have used KYB struts in the last 3 cars that I changed struts (1988 Camry, 1992 Maxima and 2000 Camry). They are good struts. Very high quality and never had any issues. They are good stock replacements.
Be sure to change the other parts like the strut mounts and other miscellaneous rubber suspension parts.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 11-09-2011, 04:34 AM   #9 (permalink)
I'm not into lowering or changing the OEM feel of the suspension, I'm just looking for good struts, Tokico was only a consideration because of other people mentioning it here in the forums.
I know that I need to change at least one of the boots but can I get away with using the same mounts... I know if they are damaged they should be changed but if they look good is there any harm in using them ?
BTW... this car has 227,000 miles on it.
Old 11-09-2011, 07:56 AM   #10 (permalink)
Luc
View Luc's Photo Gallery
There were some issues with the strut mounts for the Gen4, so there are revised replacements for those, but if you don't really have any problems, then you can reuse them. As for the dust boot, definitely replace it if it's torn because you don't want any dirt or grime to get on the strut. Since you're not lowering, go with the KYB struts, since they will give you the comfort like that of the XLE trim.
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 11-09-2011, 10:27 PM   #11 (permalink)
Also check out what Yuko did, message #17 here:
Rebuilding Front Suspension. To do or not to do.
