99 V6 manual swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2011, 09:52 AM   #1 (permalink)
View Chigga's Photo Gallery
4th Generation 99 V6 manual swap
Hi all, I'd like to swap the automatic out in the 99 and put a manual in, I've already worked out the mechanical parts that are needed:
-transmission
-axles
-flywheel/clutch
-pedal assemblies
-center console from manual car
now I'm not sure on the electrical part, do I need the ecu from the manual car? what else would I need?
Chigga is offline   Reply With Quote
Old 11-09-2011, 10:40 AM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
Because ur model could come factory with a manual ecu then it would be beneficial to install one with your swap. It will make the swap a little easier and easier to work on when things go wrong.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-09-2011, 04:08 PM   #3 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
I would agree. I see lots of people use the auto ECU's and just fool it with resistors, but they end up having problems later.
Not only will it be done correctly, you will also not have to worry about chasing wiring problems/diagrams to get the car to run.
Chris Crash is offline   Reply With Quote
Old 11-10-2011, 09:13 AM   #4 (permalink)
I havn't take a closer look, but I assume there's a separate ecu to control the transmission, does each module need coded to others in order to work? I've founded some Solara V6 manual and I'm thinking just to buy the whole car and part out what I don't need.
Old 11-10-2011, 10:01 AM   #5 (permalink)
That would be your best bet, having a parts car.
