Gen4 Fifth Gear parts required or info - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2011, 09:17 PM   #1 (permalink)
View Cedrico's Photo Gallery
4th Generation Gen4 Fifth Gear parts required or info
Hi, My 99 model Gen4 manual jumps oput of 5th when I back off the throttle..
I have removed the 5th gear cluster, being the slider and the 'hub'..
the hub teeth are worn and the Tranny guy said I will need to replace it.. Another Tranny guy said I can just reverse the 'hub' and try my luck..
Reversing it I can see is possible but not ideal..
Has anyone any experience with this issue..
I am ok with DIY... the whole set-up was easy and quick to remove..
Am told new parts are very expensive.. so I thoiught to ask memebers on their opinion, Thanks.
Cedrico is offline   Reply With Quote
Old 11-09-2011, 10:20 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Give Transtar a call and see if they can help with the parts. That should be a dual-cone synchro?
http://www.transtar1.com/locations.asp
Old 11-09-2011, 10:28 PM   #3 (permalink)
Thank you John.. I am in Australia but I will contact to them anyway.. who knows ??
As for being 'duel cone'. yes the inner mechanism has two syncro rings, so yes, I guess so.. I am just a 'keen' diyer, ( so satisying ) not that familiar with it... I will try to find info more on the Net and educate further..
Thanks ur time..
Old 11-09-2011, 10:45 PM   #4 (permalink)
hehe was wondering where Shell Harbor was.
Anyway if you manage to get a new gear at reasonable cost, then might as well replace all the synchros while at it. You may have a similar transmission supply house that can get you the entire syncrho kit, for example. Good luck.
BTW, I see that Transtar does have international sales and contact desk, however, the downside is at a minimum order of $500, but 3 days to Sydney according to the list.
http://www.transtar1.com/internationalContact.asp
