No Spark 98 camry with celica motor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2011, 08:58 PM   #1 (permalink)
View Handsonmaxima's Photo Gallery
I got the wiring harness hooked up in my 98 federal camry with a 99 celica California motor. i had to swap over the camshaft sprocket and the CPS in order to get the cps harness correctly. besides that everything is stock, all sensors but the Crank sensor are from the camry motor.
READ POST 2 ISSUE 1 HAS BEEN CORRECTED.
Handsonmaxima is offline   Reply With Quote
Old 11-10-2011, 09:50 PM   #2 (permalink)
Well, i fixed my spark issue, it was a bad ground i guess because i sandpapered everything and it started sparking like mad.
now ive figured out, my fuel pump works, my injectors do not.
i re hooked up the 2 grounds on the rear bottom of the intake manifold and i got the motor to turn over. now it just cranks and cranks with no fuel smell.
once again, any ideas about injectors not going off?
Old 11-10-2011, 10:00 PM   #3 (permalink)
View 1996camry's Photo Gallery
Injector problem.... check your fuse box under the hood..the fuse under the fuse box label "EFI". it could be blown fuse EFI (ENGINE Fuel Injector). hope that solve your issue.
1996camry is offline   Reply With Quote
