Help - Can get Climate Controls Out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2011, 09:08 AM   #1 (permalink)
View coffee-3000's Photo Gallery
3rd Generation Help - Can get Climate Controls Out
Hi. I'm trying to replace the bulbs behind the climate control knobs but I can't the the unit to slip out. I have removed all the trim from the dash and undone the screws holding in the unit. But it won't slip out. The wires are holding it in tight. I must be missing something. Any advice. Thanks, Joe
1996 V6 Camry 150K
coffee-3000 is offline   Reply With Quote
Old 11-11-2011, 09:29 AM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
When I did mine. the cable going to the A/C button was very short; not enough extra to allow the panel assembly to pull out very far. It was tough getting access to disconnect it. In fact... thinking about it a bit, I think instead, I unclipped the button from the bezel somehow and let it slide out the back.
BMR is offline   Reply With Quote
Old 11-11-2011, 09:43 AM   #3 (permalink)
Great. Thanks. I will try that. I couldn't tell if the AC button wire was the tight one or if there was another issue. I'll try to unclip if from the bottom. Thanks again, Joe
1996 V6 Camry 150K
Old 11-11-2011, 09:51 AM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Just remembered... be gentle getting that button to unclip. I broke the clip (part of the whole panel) and had to JB Weld the darn thing back together.
Old 11-11-2011, 10:15 AM   #5 (permalink)
Having a problem getting the buttons to un-clip. Will try again later.
Do you think that you un-clip it them from the bottom ? It almost seems that If I unclip those buttons, it will be impossible clipping them back.
Not giving up just yet. This photo shows where I'm at.
1996 V6 Camry 150K
Old 11-11-2011, 10:23 AM   #6 (permalink)
Could the lever for the vents be holding the unit in also ?
Do I have to remove the radio ?
I must be still missing something.
I can't seem to un-clip the AC and the defroster buttons.
Are the bulbs even back there ?
Not giving up yet.
Joe
1996 V6 Camry 150K
Old 11-11-2011, 10:38 AM   #7 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
there are holding tabs along the top and bottom that hold it in. You can clearly see it in the picture above
Old 11-11-2011, 10:46 AM   #8 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
It's been so long I've forgotten, but I remember there was a trick to it. Check out the pics in this thread. Looks like a screw beneath the temperature knob needs to come out?
I thought there was a DIY thread for this in the stickies, but I can't find it.
Edit: Found it; here. But it's for a gen 4/4.5 so not sure how helpful it'll be for ya.
Old 11-11-2011, 10:52 AM   #9 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Are the bulbs even back there?
Yes, they are. You're on the right track. I also just remembered the bulb is an oddball. Dealer only. But even the parts counter guy couldn't figure out what it was. He tried to tell me it was part of the whole panel, and I needed to buy that. Dimwit.
Old 11-11-2011, 11:15 AM   #10 (permalink)
didnt realize that hadnt been added.
Stickied now. If u guys find any more that I didnt add plz just let me know
Old 11-11-2011, 11:55 AM   #11 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Mr. P. - it was stickied, just titled a bit odd. Something like "Center console lights". Blowing thru them, I thought that meant the lights down on the shifter console. Toss the word "climate" in there and that oughta work!
Old 11-11-2011, 02:19 PM   #12 (permalink)
Thanks DMR and Mister_P. I'm getting a lot closer with your comments.
Once I removed the screw behind the temperture knob, the unit came out a little farther. I was then able to get at the tabs holding the AC and defrost buttons. But it looks like the vent lever is now holding the unit in. Should I be able to access the bulbs at this point or do I need to slide the unit out ? I can't see where the bulbs are at this point.
Not giving up yet. This photo shows where I'm at now.
1996 V6 Camry 150K
Old 11-11-2011, 02:27 PM   #13 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Dang, I wish I'd taken pics & done a DIY thread back when I did this. I think Mr. P's comment about the front coming off might be right. The bulbs are directly behind the faceplate you're lookin' at, that I know. Perhaps unsnapping the front?... around the perimeter; those click-together doo-hickies? After you get it off, it looks a lot like this photo of the gen 4/4.5 (swiped from that DIY I linked to earlier).
Old 11-11-2011, 02:48 PM   #14 (permalink)
Thanks DMR. I was just going to ask you about the face plate. I didn't think Mister_P was referring to the face plate tabs. My fault. I didn't expect the bulbs to be there.
I will snap the face plate off and see what that brings.
1996 V6 Camry 150K
Old 11-11-2011, 05:13 PM   #15 (permalink)
well, dont "Snap" it off
