How to remove switch blanks left of Steering Wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2011, 01:10 PM   #1 (permalink)
Dan3215's Avatar
View Dan3215's Photo Gallery
4th Generation How to remove switch blanks left of Steering Wheel
OK so i feel kinda dumb asking this, but I just want to get a quick answer. How do I remove one of the switch blanks to the left of the steering wheel?........ Thanks all!
'71 Monte Carlo 5% VLT all around
Dan3215 is offline   Reply With Quote
Old 11-11-2011, 01:16 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I'de pull the whole cluster plastic off so you can see behind it. Usually they are held in with two Clips on the back side.
Sometimes they are just made as part of it though
Old 11-11-2011, 01:18 PM   #3 (permalink)
Dan3215's Avatar
Yea I had a feeling....I'll probably just go pokin around and see what I can make happen. Just like old times! lol
Old 11-11-2011, 01:20 PM   #4 (permalink)
Its better than trying to pry on the front and break the surrounding. lol
Old 11-11-2011, 04:43 PM   #5 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
On the Gen 4, just remove the coin holder below the switch. Then you can reach in and pop the switch covers off from the back. Be careful not to cut yourself.
I have switches in there but that is the location right?
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 11-11-2011, 05:09 PM   #6 (permalink)
I figured thats how it was held in there. I just didnt want to tell him to go prying on it if it was actually built into the panel. lol
Old 11-11-2011, 05:34 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
On my 2000, that entire black panel came out pretty easily the same way.
2007 Camry 2.4L 5M
Old 11-11-2011, 06:09 PM   #8 (permalink)
Yuko's Avatar
I never knew the entire panel can come out.
Old 11-13-2011, 02:44 PM   #9 (permalink)
Dan3215's Avatar
lol thanks guys! I figured it was something simple like that. Popped the coin holder out and walked through everything else from there. If you don't mind me asking, what do you have that switch wired to? I'm putting fogs in so just curious if you are wired at all through the firewall?
Old 11-13-2011, 08:29 PM   #10 (permalink)
Yuko's Avatar
One switch runs my DRL fog lamps and the other disable/enable the back-up alarm. I used a Scion fog lamp switch (which was a perfect fit into the slot) to disable my fogs when needed. My back-up alarm comes on when the vehicle is in reverse but I use a ECT button from an early Tacoma to disable it. To the left of where the steering column goes through the firewall, you can run a few wire thought with the wiring harness.
Old 11-13-2011, 08:38 PM   #11 (permalink)
Gameroom cash: $109300
View fj62's Photo Gallery
I just ran wires in my 09 Highlander. I followed the hood release with the wires I ran. I had to loosen the inner fender to run the wires. Maybe your car will be easier.
Dennis
2009 Highlander Hybrid, 2007 Camry, 1995 Corolla
Previous owned
1985 Camry, 1989 Land Cruiser, 1989 Corolla All-Trac wagon
fj62 is offline   Reply With Quote
Tags
1998 camry, remove, switch, switch blanks
