92 camry v6 3vzfe
My key is stuck in my ignition and will not allow me to make the complete revolution, i can push the key inwards but wont turn at all to the left after "acc" because the key is in the ignition i cannot lock my doors however when i disconnect the battery my key is freed.
i checked the fuses inside and nothing appears blown. is there something couldve melted in the wiring harness that would lock my key in the ignition?
it also has an oem security alarm in the center console. does it lock my key in as some safety precaution?
- i dont know what these may have done but these are the things i did while in my car while listen to music through the stereo for threeish hours.
I installed a new shift knob in my camry and i cut away plenty of material and metal shavings found there way into the nooks and crannies
found the hand e-brake underneath the center consol even though i have the foot pedal parking brake. not sure if this hardware was supposed to be there. but i tried to engage it but it wouldnt stay in position
maybe stripped wires from my overdrive may have shortened out something?
tl:dr- key stuck in ignition after being completely fine hours before. key is freed when battery is disconnected.
wtfm8
edit: to add my brake(main disc brakes brake, not parking brake
is is extremely hard to press now feels likes its bottomed out.
