radiator fan and a/c fan not working..please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2011, 12:47 AM   #1 (permalink)
View 91camry59's Photo Gallery
i have a 93 2.2L camry... i replace the engine with another 2.2l engine... after doing that my radiator fan is not working... and when i turn on the a/c the fan for the a/c is not turning on... what could be the problem? i double check the wiring but still... i have a feeling its wring problem... could someone help me please
91camry59 is offline   Reply With Quote
Old 11-15-2011, 01:41 AM   #2 (permalink)
2002,5SFE
View houra's Photo Gallery
Check the ECT connector, at the bottom of radiator
DIY:1993 Camry 5SFE A/T Radiator Replacement
houra is offline   Reply With Quote
Old 11-15-2011, 10:07 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
the simpliest test is to unplug the fan switch at bottom of rad, fans should kickin with it disconnected. also check the fuses and fans relays in main relay box under hood.
Old 12-08-2011, 02:06 AM   #4 (permalink)
i check the ECT connector and the fuses... there all good..i unplug the the ECT connector the fan turns on but when i plug it back and let it run for a good 30mins the temp. gauge is at 3/4 to hot...idk what else to do..i bought a new ECT sensor but still
Old 12-08-2011, 08:56 AM   #5 (permalink)
抵抗は無駄です
fenixus's Avatar
were you unplugging the ECT switch (fan switch) at bottom of radiator? if this allows fans to run after unplugging it, then it's bad, replace the ECT switch in radiator.
