98 Camry LE Integration relay??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2011, 03:37 PM   #1 (permalink)
View Fire & Ice's Photo Gallery
O.K. guys, I'm stumped. Where EXACTLY is the integration relay on a '98 Camry LE? And once I find it how can I remove it?
My dome light bulb has been blowing and from previous posts I've seen the integration relay might be the culpret??? Of course any other ideas you might have will be appreciated. Thanks!!!
Fire & Ice is offline   Reply With Quote
Old 11-15-2011, 04:14 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I know the Integration relay on the Gen3 is located behind the Knee Bolster. You have to remove that, then it is right in front of your face. To remove it, its only clipped in IIRC.
Being a Gen4, it could be in a different location but it should be somewhere around in there. On all 4 of my camrys it is Blue in color
Old 11-15-2011, 05:07 PM   #3 (permalink)
Thanks. Still not sure but will keep checking.
Old 11-15-2011, 05:57 PM   #4 (permalink)
I found it. It's a big white box attached to the back of the fuse box (almost as big as the fuse box). It's also expensive. Thanks for the help
Mister_Perkins.
Old 11-15-2011, 05:59 PM   #5 (permalink)
Mister_Perkins.
Glad you found it, and YES .. they are expensive. I suggest traveling to a salvage yard (Pick-and-pull) and grabbing one off a wrecked 4th gen
Probably be $5.00-$20.00
Old 03-05-2012, 02:41 PM   #6 (permalink)
View tbalon's Photo Gallery
Did replacing the integration relay fix your problem with the dome light?
tbalon is offline   Reply With Quote
Old 03-05-2012, 04:43 PM   #7 (permalink)
Hi Tbalon,
Believe it or not, I didn't have to replace the integration relay ... at least not yet. Everything else in the system was working OK except for the dome light. Since I didn't see any other problems I thought I would try just replacing the bulb again. It's been working ever since. Defective bulb???
Good luck!
