5sfe turbo build help!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2011, 09:49 AM   #1 (permalink)
View m7w7j7's Photo Gallery
USA 5sfe turbo build help!!!!!!
Ok so i have been scoring the internet trying to find answers for this but i cant get a solid answer i know it can be done but i don't know exactly everything i need i have a 97 Camry 5sfe and i want to put a low boost turbo on it something like 8-10 psi i know it would probably be better to drop another engine in their or better off buying a different car but i actually like the way this car looks so i want to stick with the same engine all i want to know what exactly i need for the build is and where exactly i can find all the parts if anybody has already accomplished this feet please let me know i would appreciate it so much
m7w7j7 is offline   Reply With Quote
Old 11-16-2011, 10:11 AM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
please read:
http://mr2.com/kb/index.php?article=10
Old 11-16-2011, 10:16 AM   #3 (permalink)
see i found this post already but i for the life of me can not find any of these parts either there not made anymore or i don't know what it is
Old 11-16-2011, 10:22 AM   #4 (permalink)
also all the parts in the post are for the 3sgte does that mean all the parts for that engine are backwards compatible for the 5sfe
Old 11-16-2011, 10:35 AM   #5 (permalink)
Parts:
Pistons
http://www.theboombopshop.com/CP-Pis...k-p/sc7452.htm
connecting rods
http://www.crower.com/connecting-rod...set4-2504.html
camshaft re-grind
http://www.importperformanceparts.ne...am-toyota.html
high volume oil pump
http://www.importperformanceparts.ne...mpstoyota.html
Engine Bearings:
http://www.importperformanceparts.ne...gs-toyota.html
That took only a few minutes to find.
You will also need a bunch of other crap, such as programmable ECM, bigger injectors, turbo manifold, turbo, oil lines, Different map sensor, Different clutch (might as well change the flywheel too), bigger exhaust past the turbo, turbo piping and intercooler, etc..
Good luck on your turbo camry and let us know how you make out
Edit: no the 3SGTE is DOHC.. Although, you can put a 3sgte head onto a 5sfe, making it a 5SGTE
How to 5SGTE - 3SGTE Cylinder Head Swap on your 5SFE Block
Old 11-16-2011, 02:18 PM   #6 (permalink)
Specialmen240's Avatar
View Specialmen240's Photo Gallery
Originally Posted by trd4life View Post
I have a old school burien 5sfe turbo manifold, 315cc supra injectors, and a camry specific 2.5" downpipe for sale.
how match for the downpipe ??!
Specialmen240 is offline   Reply With Quote
Old 11-16-2011, 02:27 PM   #7 (permalink)
Creeps228's Avatar
Gameroom cash: $287318
View Creeps228's Photo Gallery
3s, and 5s motors are the same GTE means performance head turbo electronic fuel injection, FE economic head electronic fuel injection.
So parts form the 3s will fit on the 5s, since they are technically the same motor, different displacement. The 5S can work with low boost 6-8, 10 can be pushing it. 6gc.net has lots of info, search pressure2 ( i think thats hes s/n ) on his 5SFTE build. Either way you'll have to upgrade your fuel pump and injectors for safety concerns. So for your build, I'd say buy trd4lifes 5S turbo upgrade. Definitely safer route out. But you also can get a 3SGTE manifold, 3SGTE MAP Sensor, CT26 turbo, custom piping, upgraded injectors, and fuel pump. Then you need to find a location to feed oil to your turbo, and a 3sgte oil pan. But there are many different routes you can take. I've been researching for 3 years now, and I already have my 5SFTE in mind, now the costly part is getting the parts for the build. Best of luck. Keep us updated.
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 11-16-2011, 02:37 PM   #8 (permalink)
Good info here
The Following User Says Thank You to Mister_Perkins For This Useful Post:
Creeps228 (11-16-2011)
Old 11-16-2011, 03:17 PM   #9 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
How much money do you have?
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-16-2011, 03:24 PM   #10 (permalink)
way to end the thread! just kiddin
Old 11-16-2011, 10:48 PM   #11 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I've heard that Burien Toyota kit is utter balls.
If you can find any old pics of this kit, you can see why it's shitty.
The intake piping runs over the engine drastically increasing the chance of heatsoak. I've read a few people blowing their motors using that kit. If anything, I would get the essentials from Gabe and have him fabricate something different to address that issue.
That is the major thing I corrected in my intercooler setup that I'm selling.
RichieRichJP is offline   Reply With Quote
Old 11-17-2011, 02:51 AM   #12 (permalink)
Art.is.knowing
themetro's Avatar
View themetro's Photo Gallery
Sorry to bud in but would a Toyota CT26 Turbo Supra 7mgte CT-26 MK3 MKIII work for a an i4 5sfe?
themetro is offline   Reply With Quote
Old 11-17-2011, 11:52 AM   #13 (permalink)
First of all I just want to thank everyone for there help on this matter it much apprecited second of all I wanted to know do I have to rebuild my engine to install this turbo if I I'm gonna run it on such a small boost and also are these burien turbos any good I was looking at some of them and it looks like they decrease all the power http://www.meisners.net/camry/ this guy installed one and it looks like even after he rebuilt the eninge he didn't gain any performance so if thats tru I'm I going the wrong route turboing it and should instead look more towards supercharging it instead
Old 11-17-2011, 12:00 PM   #14 (permalink)
good luck finding a supercharger for the 5sfe. lol
If I were going to put a turbo on my 5sfe, and wanted to run low boost, I would at least change the Connecting rods out with aftermarket ones and have the crank machined. The 5sfe OEM Connecting rod bolts are really tiny.
Old 11-17-2011, 12:09 PM   #15 (permalink)
But is the burien turbo worth it is my question or should I look at maybe going a different route
Tags
5sfe, 97 camry, turbo
