How to remove manual window knob/handle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2011, 10:51 AM   #1 (permalink)
View vampirechicken's Photo Gallery
Question How to remove manual window knob/handle
Attempting to replace lock cylinder on my 92 Camry, and I think that all that stands in my way is to remove the manual window crank handle, but I'm unsure, and would prefer not to break it in the attempt.
Does anybody know of a guide (visual or otherwise) to removing this handle?
Thanks,
Len.
vampirechicken is offline   Reply With Quote
Old 11-17-2011, 10:55 AM   #2 (permalink)
I just found this: http://autorepair.about.com/library/.../aa092504f.htm
But other would be appreciated too.
Thanks,
Len.
Old 11-17-2011, 12:45 PM   #3 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
1. Place the handle so the knob is facing down towards the ground.
2. Grab a strong Sheet (Shop rags work well), and place it between the handle and the door panel (Behind the crank knob)
3. Slide it up towards the bottom of the crank and give it a good tug. The handle clip should pop up.
If that doesnt work, you can grab a flat head screw driver and remove the clip manually.
Heres a MSPAINT diagram for you:
The Following User Says Thank You to Mister_Perkins For This Useful Post:
vampirechicken (11-17-2011)
Old 11-17-2011, 12:47 PM   #4 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Good diagram Brandon. I was going to suggest the same technique
Chris Crash is offline   Reply With Quote
Old 11-17-2011, 12:56 PM   #5 (permalink)
Thats the easiest way I've found anyways. I'm sure theres a special tool, but who wants to go buy a 1 use tool. lol
Old 11-17-2011, 01:10 PM   #6 (permalink)
Thank you everybody.
I got everything off, got he handle off, put on the new cylinder and broke the plastic clip that holds the bottom of the lock release rod to the lock. Sigh.
Len.
