Heater not working well, losing coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2011, 06:31 PM   #1 (permalink)
View sabbates's Photo Gallery
All-
I've got a 99 Camry 5sfe that is losing coolant, but I don't see it leaking anywhere.
I suspect it has something to do with the heat exchanger, as the heater is not as hot as it used to be, and I smell anti freeze in the car.
I looked at the heater hoses that go from the engine to the firewall, and don't see any leaks.
Should I check the heat exchanger?
Where is it?
Thanks
sabbates is offline   Reply With Quote
Old 11-17-2011, 08:37 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
the heater core is behind the dash console, you will have to strip LOTS of things to get to it. from description it sounds like the coolant is leaking to cabin from the Heater Core, it might be a leaky hose or it might be a cracked heater core (get a replacement one from the junk yard or ebay, new ones are terribly expensive).
Old 11-17-2011, 09:12 PM   #3 (permalink)
T100 Road Warrior...
BamZipPow's Avatar
Gameroom cash: $863310
View BamZipPow's Photo Gallery
Talking
Originally Posted by sabbates View Post
All-
Where is it?
Thanks
Most likely the leak is in the heat exchanger. Looks like the heat exchanger should be located under the dash. You'll have to remove the lower instrument panels to gain access to it. You'll have to remove the heater hoses before you remove the heat exchanger.
What other tests have you performed? You could join the two hoses together and see if you still smell coolant in the car after the engine gits to operating temp. Have you been noticing any sort of coolant loss? When was the last time you flushed yer system? What kind of coolant have you been putting in there?
1998 T-100 SR5 2WD auto, Roadmaster Active Suspension, 6½" dropped front air dam, 4½" drop full belly pan, 4° rear diffuser, 11" side skirts, oil catch jar, AC mod, aero cap, 67% grill block = 26mpg highway!
Originally Posted by n c t t o r a
You have used a censored word. Please remove this word.
BamZipPow is offline   Reply With Quote
Old 11-17-2011, 09:28 PM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 11-17-2011, 09:32 PM   #5 (permalink)
Old 11-29-2011, 03:31 PM   #6 (permalink)
Thanks guys.
The heater core was leaking all right. I pulled it out and connected the two hoses together for now, but I need to get a new one soon.
I suppose there's no way to fix the leak?
Old 11-29-2011, 04:14 PM   #7 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
Thanks guys.
Nope.
carsrus is offline   Reply With Quote
Old 11-29-2011, 04:58 PM   #8 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
Thanks guys.
Get a new one. You'll thank us later.
Zembonez is offline   Reply With Quote
Old 11-29-2011, 08:00 PM   #9 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The picture above shows a brass/copper heater core. It's a reason why the new Toyota Pink (SLLC) coolant mean for Gen5+ all aluminum systems shouldn't be used here.
Yes, get a new heater core. Radiator shops used to solder them, but don't do it, get a new one and change coolant every 2 years with Toyota Red and 50% distilled water or the pre-mixed Valvoline Asian formula from NAPA.
