Ooooo... Just noticed you're in Puerto Rico. In some countries, the V6 used in the US-market '92 & '93 Camrys was used much longer; Australia for example. I'm not sure about Puerto Rico, but I'd guess it's the same as the US. To be sure, you wanna check the marking on the timing belt cover - It should be marked "3VZ-FE" in big letters, molded right into the plastic. Can't miss it.
