Front Passenger side Power Window Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2011, 10:37 AM   #1 (permalink)
View mastermike's Photo Gallery
When I roll the window up it walks out of the tract at the top and ends up outside the door. WTF?
mastermike is offline   Reply With Quote
Old 11-18-2011, 11:00 AM   #2 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $149050
View hardtopte72's Photo Gallery
Your window regulator has most likely failed. IIRC on Gen 4 Camrys it is 2 cables and one has probably snapped. Or if its an arm type one of the arms has broken.
Regardless you need a window regulator assembly. I would recommend buying a motor and regulator assembly and keeping your motor as a spare in case.
hardtopte72 is offline   Reply With Quote
Old 11-18-2011, 03:12 PM   #3 (permalink)
The window motor and regulator are fine the window goes up and down. When it gets close to the top it walks out of the frame.
