Motor help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2011, 01:33 AM   #1 (permalink)
View mastermike's Photo Gallery
Motor help
1996 federal 2.2 5S-FE manufactured 8/11/95 with auto trans & 105,000 miles. Motor is siezed. spun a bearing! Looking to rebuild the lower end. crank,main and rod bearings,connecting rods,and rings. Any special things I should lookout for on this project? Where should I get my parts? Any and all comments are welcome. Mike
mastermike is offline   Reply With Quote
Old 11-19-2011, 01:57 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
I would suggest bringing the block to a machine block. Also include the Crankshaft.
The Machine shop will get you the correct bearings.
Make sure to at least Hone the cylinders out before Re-ringing and installing the pistons.
The machine shop will dip, and magnaflux the block and check it for cracks.
Old 11-19-2011, 06:03 PM   #3 (permalink)
MR. Perkins, I was thinking about ordering a rebuild kit from the web that includes all gaskets and boring 20 over rather than hone. The crank main and rod bearings would remain stock but have 20 over pistons and rings. Does this sound like a good idea to you? And is there a company you would recomend purchasing this combo from? I have basic automotive knowledge but not an expert by no means. Just getting the most "GOOD" information i can before I dive into thes project. Thanks Mike
