Radiator question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2011, 11:48 AM   #1 (permalink)
View gduguid's Photo Gallery
Radiator question
I have a 96 v6 and the radiator is leaking. I found a radiator from a 93 and the radiators look almost identical except for the bottom hole being on opposite side and the fan mounts. i also found a hose long enough with the right bends, and found a way to mount the fans. Anybody know if this will work out? i have the 1mzfe engine and this one is coming out of a 3vzfe.
gduguid is offline   Reply With Quote
Old 11-19-2011, 11:53 AM   #2 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $609731
View Zembonez's Photo Gallery
I would recommend buying an aftermarket radiator made for your application rather than trying to "make one work" that is not designed for the task.
Zembonez is offline   Reply With Quote
Old 11-19-2011, 11:58 AM   #3 (permalink)
i was thinking that i just liked this one because it was all metal instead of having the plastic top.
Old 11-19-2011, 03:47 PM   #4 (permalink)
View 1996camry's Photo Gallery
that radiator will not fit... i go aftermarket, if u can afford ..but if u want to look at junkyard radiator..look for 95 model with V6.. 95 will fit your car but not 93 model. hope this help.. if u do buy aftermarket, go w/ lifetime warranty. if something wrong, you bring old radiator back and get a new radiator w/o charge. remember, kept your received
1996camry is offline   Reply With Quote
