Should I flush my transmission, or nay? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2011, 05:43 PM   #1 (permalink)
View blahh's Photo Gallery
97 camry.
Oil has been changed regularly since birth
135k miles
Just curious if it would be ill-advised to drain and refill my trans fluid/put in a new filter.
There aren't THAT many miles on it.
blahh is offline   Reply With Quote
Old 11-20-2011, 06:45 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
I'd say do it. A drain/refill is the gentlest way of doing it. But you only get about 1/3 of the oil out that way. So you might wanna do that two or three times; maybe with each next oil change.
There's a more thorough way to do it that flushes out most all of it. Here's a DYI thread showing how it's done on the 4 cylinder. If you're up to it, I'd say do that instead.
BMR is offline   Reply With Quote
Old 11-20-2011, 06:51 PM   #3 (permalink)
View daw22's Photo Gallery
I just flushed the ATF in my 96 Avalon. I used the DIY mentioned in the last post. It was actually really easy. My vote would be to do it that way. It's a much more complete fluid replacement.
daw22 is offline   Reply With Quote
Old 11-20-2011, 07:44 PM   #4 (permalink)
I was actually just looking at that! thanks!
I just wanted to make sure that I'm not going to disrupt anything due to the fluid sitting in there for the past 13 years
Old 11-22-2011, 09:10 PM   #5 (permalink)
View ferrari's Photo Gallery
I've been advised by Toyota that it is safe to flush the tranny. I've just had mine flushed with 128,000 miles. This is my second flush since 35,000 miles. All other times I've had a drain/refill. Either way is protecting your tranny.
ferrari is offline   Reply With Quote
Old 11-22-2011, 11:22 PM   #6 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
It is save to do a flush on a transmission, just not a pressure or reverse flush with a machine.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
